amazonseeeduinopython
Seeeduino Cloud - Python Setup Issues
Hi,
I am trying to setup my Python environment on a Seeeduino cloud as specified here:
http://wiki.seeed.cc/Seeeduino_Cloud_and_Grove_IoT_Starter_Kit_Powered_by_AWS/
Step 6:
opkgupdate
opkginstalldistribute
opkginstallpython-openssl
easy_install pip
pipinstallAWSIoTPythonSDK==1.0.0
Here is what happens when I execute these commands:
root@Seeed:~# opkg update
Downloadinghttp://download.linino.org/dogstick/all-in-one/latest/packages//Packages.gz.
Updated list of available packages in /var/opkg-lists/barrier_breaker.
Downloadinghttp://download.linino.org/dogstick/all-in-one/latest/packages//Packages.sig.
opSignature check failed.
Remove wrong Signature file.
root@Seeed:~# opkg install distribute
Package distribute (0.6.21-1) installed in root is up to date.
root@Seeed:~# opkg install python-openssl
Package python-openssl (2.7.3-2) installed in root is up to date.
root@Seeed:~# easy_install pip
error: can't create or remove files in install directory
The following error occurred while trying to add or remove files in the
installation directory:
    [Errno 28] No space left on device: '/usr/lib/python2.7/site-packages/test-easy-install-5294.write-test'
The installation directory you specified (via --install-dir, --prefix, or
the distutils default setting) was:
Perhaps your account does not have write access to this directory?  If the
installation directory is a system-owned directory, you may need to sign in
as the administrator or"root"account.  If you do not have administrative
access to this machine, you may wish to choose a different installation
directory, preferably one that is listed in your PYTHONPATH environment
variable.
For information on other options, you may wish to consult the
documentation at:
  http://packages.python.org/distribute/easy_install.html
Please make the appropriate changes for your system and try again.
Thanks,
Steve
stevealbrightDec 05,2017 10:21 AMAdd Comment
Comment
Popular Topics
