Protection Circuit for 5V Regulator
19540Published On Nov 30,2016 11:19 AMshare0
Originally written by
Generic crowbar
A generic 9.1 V, 250 mA crowbar circuit that uses a silicon controlled rectifier, or SCR, to short the output terminals
If the input voltage to the circuit reaches a certain threshold (9.1 V in the example above), a Zener diode breaks down and causes either a TRIAC or SCR to short power and ground... as if you threw a crowbar across the terminals.This forces a lot of current through the device but immediately lowers the voltage. An inline fuse will then electrically disconnect the load (the Wandboard in our case) from the supply. In the case of an SCR, when the Zener diode breaks down, a voltage appears on the gate terminal of the SCR. If this is above the SCR's gate activation voltage, the device turns on.
Our Crowbar Circuit
Simulation
Layout
Design Files
Comment
James
Followers20
Projects98
Components
Fusion PCB
$9.90 Add To Cart
Fusion PCBA
$10.00 Add To Cart
Add All To Cart
Related Recipes
Popular Recipes
