Linkit One Energy Harvesting
19651Published On Jun 26,2016 08:48 AMshare1
By using energy harvesting technology I devised a method to power the Internet Of Things board: Mediatek Link it One. By creating a simple circuit using energy harvesting ICs such as the LTC3108 I was able to harvest enough energy from solar sources in low-light conditions to power the Link it One. This board can also be used to power Arduino boards and PICAXE micro-controllers.
In this instructable I shall explain how I did it.
Components:
• SSOP to DIP layout breakout board such as these, the side with 0.65mm spacing shall be used http://ebay.eu/1NLeJsQ
• LTC3108 Energy harvesting IC from Linear electronics in the SSOP 16 Lead package (I got these as a free sample off the Linear electronics website but you can also buy them off ebay)
• Coilcraft 1:100 transformer (I also got these as a free sample)
• 330pF capacitor (0805 SMD or through-hole)
• 1nF capacitor (0805 SMD or through-hole)
• 1uF capacitor (0805 SMD or through-hole)
• 220uF Capacitor (either SMD or through-hole)
• 470uF capacitor (either SMD or through-hole)
• Some headers 2.54mm spacing
• A supercapacitor (e.g. 1F, 0.33F)
A N-Channel MOSFET
A 1M resistor
• A type of prototyping board e.g. veroboard
• Some wire for connections on the prototyping board
• A solar cell (should produce 0.55v in bright sunlight.
The LTC3108 coupled with the appropriate circuitry is able to step-up voltages as little as 20mv to 3.3v. I made the suggested circuit as shown on page 1 of the datasheet which I have included for your own convenience.
Step 1: Solder the LTC3108 to the break-out board
Step 2: Solder the transformer onto the proto-board
Step 3: Place on other components and linkwires
Step 4: Add the 1uF capacitor.
Step 5: Add the 220uF input capacitor
Step 6: Add in storage super capacitor
Step 7: Use PGood to trigger MOSFET
Step 8: Testing
Comment
Berlina
Followers20
Projects79
Components
LinkIt ONE
$59.00 Add To Cart
Related Recipes
Popular Recipes
