How to Prototype Without Using Printed Circuit Boards
147561Published On Sep 16,2008 17:29 PMshare1
When I learned how to build ‘one-off’ projects thirty years ago, I used the"wire wrapping"technique. Back then, I had access to an electronics shop with a $100 wire wrapping gun, kynar wire and a supply of wire wrap IC sockets. At home, however, with limited resources and no wire wrap gun, I had to make do, so I developed a technique that uses perfboard, kynar wire and solder that results in a neat, quick to assemble and very dependable electronic board.
Assuming you've developed your design on a breadboard and made a schematic, the steps to build your circuit board are:
1.  Place your components on the circuit board
2.  Plan the wiring on the board using a Perfboard Layout Planning Sheet
3.  Connect the components using Kynar wire
Step 1 What You'll Need
Step 2 Place your components on the circuit board
Step 3 Make your wiring plan
Step 4 Connect the components using Kynar wire...
Step 5 Measure and cut the wire
Step 6 Make loops around the wire ends
Step 7 Crimp the loops over the pins, then solder them
Step 8 Testing your work
Comment
xieliangliang
Followers0
Projects29
Components
ProtoBoard 7cm * 10cm - 2.54mm
$2.50 Add To Cart
Related Recipes
Popular Recipes
