Home automation with Raspberry Pi 2 and Node-RED
28870Published On Oct 18,2016 17:17 PMshare0
Originally written by StuartChilds
Node-RED is a visual tool for wiring the Internet of Things that can be run on a Raspberry Pi and allows for rapid prototyping of projects. In this tutorial we will first set up Node-RED on a Raspberry Pi 2, before creating a flow that will read a temperature sensor and control a LightwaveRF mains socket.
start
Hardware
Setting up LightwaveRF control
Installing Node-RED
Building a Node-RED flow
Comment
James
Followers20
Projects98
Components
Fusion PCB
$9.90 Add To Cart
Temperature sensor for Raspberry Pi - LM75
$7.90 Add To Cart
easyRadio 433MHZ USB Transmitter for Raspberry Pi
$82.00 Add To Cart
Breadboard Jumper Wire Pack(241mm 200mm 160mm 117mm)
$5.00 Add To Cart
1 pin dual-female jumper wire - 300mm
$0.30 Add To Cart
0805 SMT Resistor sample book - 8496 pcs in 177 values(free shipping)
$60.00 Add To Cart
IP Sockets Solder Tail - 28-Pin 0.3
$0.50 Add To Cart
Antenna IPX for GPS
$14.60 Add To Cart
Add All To Cart
Related Recipes
Popular Recipes
