Blinds Automation
34483Published On May 14,2016 18:18 PMshare3
Automating you blinds is easy thanks to the LinkIt ONE platform. To rotate the blinds wand/rod we will use a continuos rotation servo. And the movement of the blinds will be triggered from a Wi-Fi web app hosted on the LinkIt one as part of the Arduino code, which you can access using your phone,tablet or computer.Note: If you have a normal servo modify it to make it a continuous rotation servo, you will find vaiours tutorials on the web
Step by Step Introduction
Comment
Carmelito
Followers0
Projects2
Components
Breadboard Jumper Wire Pack(200mm/165mm/125mm/80mm)
$5.00 Add To Cart
LinkIt ONE
$59.00 Add To Cart
TowerPro Airplane 9g SG-90 Mini Servo
$7.00 Add To Cart
Add All To Cart
Related Recipes
Popular Recipes
