Automatic Water Level Controller
118353Published On Nov 23,2009 16:10 PMshare3
There are many ways like using a float sensor to determine the water level, or using probes to detect peak and low level in the tank.How to measure water level without using probe or contacting with water?yeah there is a way just using a Ultrasonic sensor, this is very simple where the level of water is measured using ultrasonic sensor which gives the depth , by determining the tank depth we can set the maximum and minimum level
Step by Step Introduction
Comment
mag
Followers4
Projects27
Components
Basic Bread board - 16.5*5.5 cm
$6.90 Add To Cart
Wall Adapter Power Supply - 9VDC 1A
$3.90 Add To Cart
Breadboard Jumper Wire Pack(200mm/165mm/125mm/80mm)
$5.00 Add To Cart
Grove - Relay
$2.90 Add To Cart
LCD 16*2 Characters - Green Yellow back light
$7.95 Add To Cart
Grove - Ultrasonic Ranger
$3.90 Add To Cart
Arduino Uno Rev3
$24.95 Add To Cart
Add All To Cart
Related Recipes
Popular Recipes
