!kea IOT of furniture
39670Published On Jun 07,2010 11:58 AMshare0
This project is to make life easy and fun in the bedroom... >.< - Smart bedroom light ( PIR and LDR used + sorfware ) + Bonsai tree moisture led level indicator + Air / Humidity & Temperature color Led level indicator ( Red = open window, Green blink is close the window )+ And connecting it to interwebs ++ And to tell that my closed has own app :D
Step by Step Introduction
Comment
PaulStefaan
Followers0
Projects1
Components
Wall-Adapter Power Supply ( Power needed for Strip )
$3.90 Add To Cart
Grove Air quality ( optimal )
$9.90 Add To Cart
WiFi-Micro-Kit ( Banana version )
$20.00 Add To Cart
Grove-HCHO-Sensor ( optimal )
$14.90 Add To Cart
Mini-PIR-Motion-Sensor
$5.90 Add To Cart
Grove-Light-SensorP
$2.90 Add To Cart
Grove-TempHumi-Sensor ( optimal )
$5.90 Add To Cart
Seeeduino-Lotus ( Mango version )
$17.50 Add To Cart
RGB-LED-strip ( 1m a 2 m up to you )
$9.90 Add To Cart
Grove-Buzzer ( optimal if led is not your thing )
$1.90 Add To Cart
Grove-Moisture-Sensor ( optimal if your treehugger )
$2.99 Add To Cart
Add All To Cart
Related Recipes
Popular Recipes
